There is a problem with the keyboard simulation in NX on Vista and Win7-64bit. The command mapping in 3DxWare does not work correctly and the mapped commands are not executed.
The issue is related to the UAC [User Account Control] in Windows. The UAC specifically stops the mechanism the 3DxNX software uses to send macros. One option is to turn off the UAC, however, this lowers the level of security so it is not a recommended solution. If you want to temporaily turn off the UAC you can type UAC in the search bar next to the Start button then lower the UAC slider.
Another option is to use the new beta software since it uses a different mechanism to generate the commands.[
http://www.3dconnexion.com/supported-so ... xlabs.html]
Beta software testing is typically done on personal or non-production PCs. If this is a network PC, please check with your IT department before switching to the beta driver.Technical support for software in beta testing is limited to the forum. You can visit our forum to give feedback, share your experiences and get advice.[ 3DxWare 10 Beta Forum at
http://www.3dconnexion.com/forum/ ]
The internal bug tracking number for this issue is #5293. Please check our release notes when a new driver to see when a fix is available for this problem.
Driver releases are posted on our download page on the day they become available and are not pre-announced.The Release Notes .PDF for the driver lists issues that have been addressed and plugins that have been updated .[
http://www.3dconnexion.com/service/drivers.html]
