TDxInput in Excel VBA
Zire18
Post by Zire18 »
iam trying to use the sdk in Excel , but with the following Code i only receive "0". Thank you for your help
Private WithEvents Sensor1 As TDxInput.Sensor
Private WithEvents Keyboard1 As TDxInput.Keyboard
Private WithEvents Device1 As TDxInput.Device
Private Sub CommandButton1_Click()
Set Device1 = New TDxInput.Device
Set Sensor1 = Device1.Sensor
Set Keyboard1 = Device1.Keyboard
Device1.Connect
Dim Translation1 As TDxInput.Vector3D
Set Translation1 = Sensor1.translation
Dim Rotation1 As TDxInput.AngleAxis
Set Rotation1 = Sensor1.rotation
Label1.Caption = Translation1.X
End Sub
We have no idea. We have no experience trying to use that interface in VBA with Excel.
The 3DxWare.log file may help to diagnose what is going wrong.
Typically, when we see problems with COM, it is because objects go out of scope and get destroyed when you are not aware of it.
Hi Zire18,
As Jim suggested, try declaring the Sensor1 and Keyboard1 variables in the module scope (outside a funtion or subroutine).
mbonk
Re: TDxInput in Excel VBA
Post by mbonk »
Zire18 wrote:Hello,
End Sub
I would agree with Nuno.
The quoted code creates a new instance of the tdxinput for 3dxware. 3dxware only routes 3D Mouse data to a foreground app with a device instance. Invoking the subroutine creates a new device and querying it for already received data will draw a blank - it is new.
The correct practice would be to create the device once at startup/open and then only query the data in the subroutine.
Markus
XOz3wdWcsePi
Post by XOz3wdWcsePi »
Is there an example of coordinates successfully being sent to excel?
