hi,all
can i use two 3dconnexion in one application ?
thanks
wly
mtrzcinski
Re: use two 3dconnexion in one application
http://www.3dconnexion.eu/supported-sof ... where.htmlwly86 wrote:hi,all
thanks
wly
I think with 3DxWare 10 you can work with multiply devices at the same time
Sorry you cannot use 2 devices at the same time using the currently supported driver.
The reason is the same as plugging in 2 standard mice each device would try to take control.
I believe the same is true when using the Beta driver.
It will allow you to have more than one device plugged in but you cant use both at the same time.
You can use any number of devices you want with 3DxWare 10. The question is what do you want to do with them. If you are a software developer you can do anything you want. If you want to use the driver, you can assign each type of device to different tasks, but currently you can not assign two devices of the same type (e.g. SpaceNavigator) to different tasks.
thank you !
i have try 3DxWare 10,that allow me use two divice,but cannot do different tasks.
maybe i cannot do that with the currently supported driver.
wly86,
What are you trying to do with the two devices? Which devices are these?
