I hold the pen in my right hand (Cintiq 22 hd TOUCH) and my left hand is on the spacemouse. It happens that every time the pen touches the screen, the canvas is filled with images that, in order to disappear, require me to go to the Layer menu and press clear. Has anyone else experienced this problem? Thanks in advance! My zbrush is 2022.06 and my spacemouse is compact.
Link of problem :
https://youtu.be/SFtZA4AHzkw
ZBRUSH - Problem with canvas - I need to clear the layer every time.
marcinhorj
Re: ZBRUSH - Problem with canvas - I need to clear the layer every time.
Hello Marcinhorj,
Does this only happen when the driver is installed an enabled?
How long have you been having this issue?
if you were to unplug/disconnect the SpaceMouse is the issue still there?
Im also having this problem quite a bit.
Its happens when I move the Spacemouse joystick (in any direction) at the same time as click with a mouse and also when I use a wacom pen on the screen of Cintiq pro 24.
It starts doing this all of sudden will only stop doing it once I restart zbrush.
Does it both wired and wireless. Unplugging the Spacemouse doesnt make a difference.
Zbrush 23.0.1 Build 31
It does this on both Mac and PC for me. All latest versions of OS and drivers.
IvanTorres
Please
I have the same problem, very annoying. I had to create a shortcut to delete the layer every time it is generated.
