Spacemouse USB drivers not working as intended
APOS80
Post by APOS80 »
Bought an old Spacemouse USB for some navigation but the driver from 2021, the one that "works", is not behaving.
The Trainer just buggs out befor you can try it, even though i dont need it.
AND settings as Speed an Macro isnt saved and therefore doesnt work.
I know the Spacemouse USB is discontinued but why isnt the drivers work??
javierolson
Re: Spacemouse USB drivers not working as intended
Post by javierolson »
Hello, I also had the same issue. Then, I try try running the driver in compatibility mode. Right-click on the driver's installation file, select "Properties," go to the "Compatibility" tab, and choose an earlier version of Windows that the driver is known to work with. Fortunately, the issue is solved. You can try applying this method
