C4D - change Motionmodel in App
prowlmedia
Post by prowlmedia »
So the old driver had the Dockable window to control the speed and motion model from Fly / Object etc. This was really quick and intuitive.
You could quickly change the speed, which is important when changing scale.
Could even reverse the axis ( Object mode is still wrong on the new plugin in for me)
The new driver seems like you can only change this in the 3D connection settings / Configure Cinema 4D 2023 / Navigation / Motionmodel - which is a drop down and also slows things down.
Can these settings be accessed from within C4D? As an extension perhaps?
Failing that
Can they be changed ON the device - It doesn't see like they can on the Buttons Tab > Mapping (3D Connexion) - although increase speed does appear to be changeable
Falling that
Can a system wide short cut change anything on the preference pane? I am guessing not as it's a drop down
It's really annoying. The new driver is much better and works well ( actually I get a lot more drifting and have to calibrate often ) but the control of it is awful now.
Screenshot 2023-09-18 at 10.11.23.png (84.7 KiB) Viewed 118092 times
