SpaceMouse Enterprise Autocad Lt Zoom/Pan Maximise Viewport
peterbowenpm
Post by peterbowenpm »
Hello
This is an issue I've had for some time and wonder if anyone has a solution.
I use a SpaceMouse Enterprise with AutoCAD LT on the PC for zooming in and out and panning in 2D.
The situation arises when I have more than one layout. If I open a drawing, select layout 1 and maximise the viewport I can use the SpaceMouse Enterprise to zoom and pan as expected.
If I then change to the second layout or any other layout apart from the first one I opened and maximise viewport the SpaceMouse Enterprise becomes unresponsive.
If I go back to layout 1 the SpaceMouse Enterprise responds again as normal.
I have to close and open the drawing each time I want to maximise the viewport in a particular layout and use the SpaceMouse Enterprise.
Becomes very frustrating after a while.
Anyone have a solution?
Re: SpaceMouse Enterprise Autocad Lt Zoom/Pan Maximise Viewport
Call the 3Dconnexion support. Maybe it's the limitation of 3DxWare drier plug-in/add-in for AutoCAD.
