Spacemouse too sensitive after updating to latest drivers
Endlessdescent
Post by Endlessdescent »
I recently updated my drivers to 10.8.16.3641 & 17.8.16.20445
I'm on a Spacemouse Pro Wireless (FW: 4.38)
Previously the sensitively was great. I mostly use it in Daz Studio. Everything was working perfectly but I needed to update drivers for UE5 use.
Everything functions as intended now except the knob is waaaay too sensitive. I've turned down the speed all the way on the main slider, and turned down all the speed settings in "advanced" and it works okay, but is still slightly too fast with everything set as slow as possible.
I'm working on extremely HD models, I need to be able to move the camera very slow at times to be precise. The speed curve as it currently is not acceptable for my use.
AmroSalih
Re: Spacemouse too sensitive after updating to latest drivers
Post by AmroSalih »
Please visit https://3dconnexion.com/support/ to contact with our technical support.
I see comments on the DAZ forum that it has always(?) been too sensitive.
Did you perhaps have a custom cfg file before that scaled it down?
If you make too large of an update of the 3DxWare drivers, your old cfg file may be incompatible and it may be moved to a bak directory.
