Wheel problem
Adam.H
Wheel problem
Post by Adam.H »
I have a problem with the wheel. Wheel skips by itself or it only works in one direction. I use Cad MousePro. I understand that a failure will happen. I'm trying to register on the website to get some help from support, but it's just not possible. Not only is it blocking my emails, but now it has blocked my access with the message "You have been locked out of this site". I can understand that something is done so that it breaks, but not after 2 months. Additionally, there are problems with registration, and access to the website is now blocked.waste of time
M0Dark
Re: Wheel problem
Post by M0Dark »
Great to see they use the same unfit for purpose scroll wheel on the Pro as the compact Cadmouse. 3/4 of ours have failed with the same issue.
Maybe like the blutooth connectivity in 14 years they'll do something about it.
Re: Wheel problem
M0Dark wrote: Thu Aug 22, 2024 6:15 am Great to see they use the same unfit for purpose scroll wheel on the Pro as the compact Cadmouse. 3/4 of ours have failed with the same issue.
Start RMA process to replace the CadMouse Pro Wireless with failed scroll wheel.
