OneNote and PowerPoint
Alakelele
Post by Alakelele »
Hello all, I just want to report that the SpaceMouse is still not working in PowerPoint and has very limited functionality in Onenote, only scrolling up and down.
What would it take to get either Microsoft and/or 3Dconnexion to check on that and make things moving again ?
Please help by commenting and or upvoting this thread
Re: OneNote and PowerPoint
SpaceMouse is specifically designed for 3D software like CAD/CAM/CAE software, not for office applications like PowerPoint or OneNote.
mhoopes
Post by mhoopes »
3Dconnexion is supported directly by a number of applications, some of which are listed here:
https://3dconnexion.com/us/software/?so ... dustry=all
It's generally up to the application developers to provide this support.
If an application is not directly supported, Rx (vertical tilt) emulates the mouse wheel by default. Some applications support horizontal scrolling with Shift+MouseWheel, but OneNote and PowerPoint aren't among them.
There are workarounds, if one is willing to deploy AutoHotKey, and edit the 3Dconnexion ONENOTE KMJ device profile to make Ry control horizontal scrolling.
https://www.reddit.com/r/OneNote/commen ... scrolling/
Here's the part of the 3Dconnexion xml that would be modified. The <Enabled>...</Enabled> and <Output>...</Output> lines would be replaced to bring Shift+MouseWheel to Ry.
The best way to start this is to go to 3DxWare Properties, with OneNote active in it, and enable Ry (horizontal tilt). The ONENOTE-KMJ.xml file will show up, and can be edited in a text editor (location: %appdata%\3DxWare\Cfg).
        <Axis>
          <Enabled>true</Enabled>
          <Input>
            <Min>-512</Min>
            <Max>511</Max>
          </Input>
          <Output>
            <ActionID>HIDMouse_Wheel</ActionID>
            <Modifiers>
              <Modifier>Shift</Modifier>
            </Modifiers>
          </Output>
        </Axis>
The AutoHotkey code that worked for me (Windows 11, AutoHotkey 2) is as follows:
#Requires AutoHotkey v2.0
#HotIf WinActive("ahk_exe ONENOTE.EXE") or WinActive("ahk_exe ApplicationFrameHost.exe")
Shift & WheelDown::Click "WheelRight"
Shift & WheelUp::Click "WheelLeft"
Michael Hoopes
mhoopes
Post by mhoopes »
As for AutoHotKey in the latest Windows 11 versions (I'm in 22H2), recent Windows updates appear to have obscured the startup location that was launching my other scripts, though they still are working.
I placed the latest one (calling it OneNoteHorizScroll-1.ahk, which only contains the latter code above) in this folder:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
Michael Hoopes
mhoopes
Post by mhoopes »
One more thing: I've found that I prefer the Dominant setting in 3DxWare for Mouse Wheel emulation. Diagonal scroll is otherwise a bit etch-a-sketchy.
Michael Hoopes
Alakelele
Post by Alakelele »
Same situation here, too bad Microsoft is not embracing the 3dmouse
Alakelele
Post by Alakelele »
mhoopes wrote: Mon Mar 11, 2024 2:22 pm 3Dconnexion is supported directly by a number of applications, some of which are listed here:
        <Axis>
          <Input>
            <Min>-512</Min>
            <Max>511</Max>
          </Input>
          <Output>
            <Modifiers>
            </Modifiers>
          </Output>
        </Axis>
Where do you find the ONENOTE KMJ file ?
AmroSalih
Post by AmroSalih »
First, launch your OneNote desktop app. In the next step, open 3Dconnexion Settings.
In the 3DxWare main settings panel, select your desired device from the list.
Open the "Buttons" or "Advanced Settings" menu. Ensure that your OneNote app had been brought into focus of the 3DxWare driver settings panel.
Assign the desired macro or radial menu command to the desired programable button.
In OneNote, press the newly programmed button.
The "OneNote KMJ.xml" can be found in %appdata%\3Dconnexion\3DxWare\cfg
Hesoyam
Post by Hesoyam »
I had the same issue, and updating the driver fixed everything for me. Also make sure the device is detected properly in the 3Dconnexion settings panel before launching any software.
Alakelele
Post by Alakelele »
So sad that Microsoft is incapable of truly updating and improving their software.....
