How to disable from specific programs
DrSpaceman
Post by DrSpaceman »
Hi, this may be an easy one. How do I disable my space pilot from Autocad? When working between Inventor and Autocad, it is really, REALLY annoying to bump the pilot and throw my Acad drawing out of whack. Sometimes, it actually crashes Acad. I never need the device for Acad anyway, and know there HAS to be a fix for this. Any help is appreciated
Bryan
Re: How to disable from specific programs
Post by Bryan »
Dear DrSpaceman,
You may manually start and stop our drivers.
Start
All Programs
Driver
Start Driver / Stop Driver
Sincerely,
Bryan
Fred
Post by Fred »
If your running Autocad 2007-2010.
Go to appload" command in AutoCAD to unload 3dxautocad.arx
If your running Autocad 2011-2012 support was added natively turn off the navbar
If you type navbar in the search field it has options to disable or enable.
With 3DxWare 10, you can disable all the axes quite easily in the AutoCAD profile.
