Visual Foxpro
Visual Foxpro
A user contributed this code to show the basics of accessing the 3D mouse data in Visual Foxpro:
&& just for testing, reading a 3Dconnexion mouse into Visual Foxpro.
&& This is not finished code,
&& Cleanup needs to be done,
&& should not be public variables. Just for testing.
PUBLIC omouse,oevents,osensor
oevents = NEWOBJECT("MouseHandler")			&& Create an instance of the event handler
omouse = CREATEOBJECTEX("TDxInput.Device",[])		&& Create the object from the 3dConnection library
omouse.CONNECT						&& connect the mouse (Maybe not neccessary?)
=EVENTHANDLER(omouse.sensor, oevents)			&& Set up the event binding
=EVENTHANDLER(omouse.keyboard, oevents)			&& for both sensor as well as keyboard events
RETURN							&& Done
DEFINE CLASS MouseHandler AS SESSION
	IMPLEMENTS   _ISensorEvents  IN TDxInput.DEVICE		&& Sensor events
	IMPLEMENTS   _IKeyboardEvents  IN TDxInput.DEVICE	&& Keyboard events
	PROCEDURE _ISensorEvents_SensorInput			&& Capture the input event
		ACTIVATE SCREEN					&& Print it on screen
		? omouse.sensor.ROTATION.x
		?? omouse.sensor.ROTATION.Y
		?? omouse.sensor.ROTATION.z
		?? omouse.sensor.TRANSLATION.x
		?? omouse.sensor.TRANSLATION.Y
		?? omouse.sensor.TRANSLATION.z
		RETURN
 	PROCEDURE _IKeyboardEvents_KeyDown(m_key)
		ACTIVATE SCREEN
 			? m_key
 		RETURN
	PROCEDURE _IKeyboardEvents_Keyup(m_key)
 			? m_key
		RETURN
ENDDEFINE
