<Axis>
<Enabled>true</Enabled>
<Input>
<Min>0</Min>
<Max>511</Max>
<!-[list]<Deadband>200</Deadband> -->[/list]
</Input>
<Output>
<ActionID>HIDMouse_Wheel</ActionID>
<Scale>3.00</Scale>
<Reversed>true</Reversed>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>0</Max>
</Input>
<Output>
<Scale>3.00</Scale>
</Output>
</Axis>
...Also in the above xml snippet, how is just the use of HIDMouse_Wheel determining the scrolling direction?
I thought <Reversed>true</Reversed> is used to invert the axis physical direction. Maybe its being used for both purposes in this case
