SpaceMouse Wireless works only when rotated 180 degrees
fxmech
Post by fxmech »
I installed the latest driver and started to have issues navigating... I was unable to fix it as the reverse features in the preferences don't seem to be doing anything. I finally got everything to work correctly by spinning the space mouse so that the USB chord faces the user (180deg from normal).
Does anyone know how to correct this? I am using a space mouse wireless model but using it in wired mode. I tried it with my wired-only space mouse and had the same results so it has to be in the settings or in the driver itself. I use it with FUSION360, but earlier today I was trying to get it to work with plasticity.... Plasticity has its own preference adjustments, but I'm worried that something in there messed up Fusion as well...
What can I do to bring things back to normal?
AmroSalih
Re: SpaceMouse Wireless works only when rotated 180 degrees
Post by AmroSalih »
fxmech
Post by fxmech »
I just got it working. I had to do a full uninstall. I am still not sure if the problem came about because of my attempts at getting it to work with Plasticity, of if it happened when I installed the latest firmware, but the uninstall/reinstall seems to have solved the issue.
