Enterprise LCD, Global.cfg - Colors & Text Size
Vix
Post by Vix »
Howdy howdy!
I wanted to make a global dark theme for my SpaceMouse Enterprise's LCD screen and this is coming along quite nicely.
Although, I've hit a bit of a snag. If I supplement the <Settings> block with <TextSize>Large</TextSize> then my colors end up being mangled.
Example without TextSize large:
Example with TextSize large:
<?xml version="1.0" encoding="utf-8"?>
(c) Copyright 3Dconnexion. All rights reserved.
$Revision: 20533 $
<Global xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" Default="false" CfgFormatVersion="1.3" ThisFileVersion="1.35">
  <CfgProperties>
    <ID>ID_Global_Cfg</ID>
    <InheritsFromID>ID_Global_Cfg</InheritsFromID>
    <Name>STR_GLOBALCFG</Name>
  </CfgProperties>
  <AuthorInfo>
    <DriverVersion>17.8.20.20889</DriverVersion>
    <LastChange>
      <Tool>3DxSmartUI.exe</Tool>
      <Version>1.2.24106.20869</Version>
      <Date>6/13/2024 11:21:15 PM UTC</Date>
      <User>vix</User>
    </LastChange>
  </AuthorInfo>
  <Devices>
    <Device>
      <ID>ID_ProductID_C633</ID>
      <Settings>
        <LCDIntensity>100</LCDIntensity>
        <BackColor>#000000</BackColor>
        <ForeColor>#B4D455</ForeColor>
        <ButtonBackColor>#1c1c1c</ButtonBackColor>
        <ButtonForeColor>#B4D455</ButtonForeColor>
        <ButtonPressBackColor>#ff248dcf</ButtonPressBackColor>
      </Settings>
    </Device>
  </Devices>
</Global>
On another note; is there a comprehensive explanation of which functions can be used for visual customization?
I'd like to be able to change the size of the icons of custom macros, for instance.
Re: Enterprise LCD, Global.cfg - Colors & Text Size
The text background has been fixed for the next release. Thanks for pointing it out.
There is no external documentation on the XML format. It is a moving target.
For most cases, I put the available elements into Base.xml (as you have found). You can consider it the dictionary to pull words from for your app-specific cfg.
agiorgitis
Post by agiorgitis »
The black background idea is excellent, can it be implemented in the official software too?
A dark theme.
I run almost all of my cad applications in dark mode and this would be very handy when working at night.
