What are the valid values for:
action
data
deley
id
keycode
modifiers
repeat
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>macros</key>
<array>
<dict>
<key>id</key>
<integer>2</integer>
<key>name</key>
<string>line down</string>
<key>notes</key>
<string></string>
<key>steps</key>
<array>
<dict>
<key>cmd</key>
<integer>1</integer>
<key>data</key>
<integer>125</integer>
</dict>
</array>
</dict>
</array>
<key>settings</key>
<array>
<dict>
<key>active</key>
<true/>
<key>configName</key>
<string>Firefox</string>
<key>devices</key>
<dict>
<key>SpaceExplorer</key>
<dict>
<key>assignments</key>
<dict>
<key>button01</key>
<dict>
<key>action</key>
<integer>35</integer>
<key>data</key>
<string></string>
<key>delay</key>
<integer>0</integer>
<key>id</key>
<key>keyCode</key>
<integer>255</integer>
<key>modifiers</key>
<key>repeat</key>
</dict>
