Spacemouse wireless
Ember crow
Spacemouse wireless
Post by Ember crow »
I just received my spacemouse wireless but it turned out to be the version with the mini usb instead of usb c and what I want to know is if there is basically any difference between the two versions besides the different usb ports as that would decide if I return this one and have a better look and order the usb c one
skmiec
Re: Spacemouse wireless
Post by skmiec »
Hi Ember crow
So the main differance is that the new version with mini usb has also possibility to connect the device with PC via Bluetooth.
There are also small cosmetic changes in case materials.
Here are links to both products:
https://3dconnexion.com/uk/product/spac ... eless/buy/
https://3dconnexion.com/uk/product/spac ... ess-1/buy/
beautyselena
Post by beautyselena »
The primary difference between the Space Mouse Wireless versions with mini USB and USB C ports is the type of connector used for charging and data transfer. Functionality performance and features of the device itself remain the same regardless of the port type. If having a USB-C port is crucial for compatibility with your current setup or future proofing it may be worth exchanging it otherwise the mini USB version will serve you just as well.
