I am having a problem editing a cube when I have created a proxy. When I alter the subdivisions using the channel box the geometry screws up.
Here are steps to reproduce:
Maya 2013 SP1 64bit
3DConnexion Space Navigator
Create a polygon cube with basic settings
Scale in the X
Scale in the Y
Scale in the Z
Do each scale individually
Then create a proxy
2 Subdivisions and keep transparent
Move the cube out of the way.
In the channel box, set the subdivisions width to 3 in the polycube inputs.
Hopefully you will see a messed up mesh.
I tried this on my laptop using the 32bit version, I don't have the space navigator installed and it worked fine. So it would suggest an issue with the drivers.
Could you get it please, and if it is an issue add it to your list to fix please.
thanks
Andrew
Maya 2013 64bit SP1 - Poly Cube - Proxy issue
AndrewHenson
