Revit 2025(.1) Forward/backward zoom speed is too high
In Revit 2025, the zoom speed for forward/ backward motion is too high on the default speed setting. I have changed the speed for this individual axis, but even then, navigation is choppy. In fact the speed by default was so high that there appeared to be a driver issue, as any zoom movement caused the model to disappear altogether. When I changed the zoom direction to up/ down, with the up/ down speed set to the default, everything worked as it should. This applies to 3dxware 10.8.20 and 10.8.21 on Windows 10.0.19045.
- Attachments
- Screenshot 2024-07-15 150255.png (143.41 KiB) Viewed 2405 times
Re: Revit 2025(.1) Forward/backward zoom speed is too high
