Sequoia Public Beta
zoomer
Sequoia Public Beta
Post by zoomer »
Did anyone try already and can report of problems with 3DConnexion drivers ?
CMattX
Re: Sequoia Public Beta
Post by CMattX »
If you're using Public Betas of macOS there is a 3Dconnexion Insider Program for pre-release driver versions you can sign up for to test out.
https://3dconnexion.com/support/faq/3dc ... r-program/
Ryley Feeney
Post by Ryley Feeney »
Some applications may not support the latest 3DConnexion drivers, leading to functionality issues.
Clarin
Post by Clarin »
My space mouse is not compatible with 14.6!
I can't even re-install the driver, it just hangup.
I have tried 15 beta 4, same thing, and you have no newer releases, any help is welcome.
zoomer
Post by zoomer »
I am on Sequoia Public Beta 2 (and now PB 3)
I did not plug-in my Enterprise so far but the old original CADMouse
does not feel any suspicious.
Beside that we have here typical summer humidity (60-70%) and clicks of
mostly all Mouse Buttons do not work reliable above 60% air humidity.
Mostly unwanted double clicks, which is a nightmare when you want
to e.g. delete a "single" eMail only, or want to bring a background
Window back to front - without maximizing the Window.
(Already the second RMA replacement and again corroded)
So I use the CADMouse for Apps only where I need a middle click.
For main usage I went back to my old Magic Mouse.
cgarch
Post by cgarch »
Clarin wrote: ↑Tue Aug 06, 2024 12:36 pm Hi,
<snip>
+1
Since 14.6.1 was installed Space Mouse no longer works in BT. Have to connect it with a cable . .
BT dialog box does not offer "Connect" though it shows the SM. System info doesn't provide any insight either
Mopipari
Post by Mopipari »
After updating my MacBook Air to Sequoia, my Space Mouse Compact is non- functional in SketchUp 2024 and wonky in Rhino 8. I’m hoping there is a new driver soon.
sea_dragons
Post by sea_dragons »
Any update on 3DConnexion under Sequoia? I've been putting off update to avoid mid-project surprises but I'd like to move if it's safe :)
