CADMouse Pro - Modo
SteedMaker
CADMouse Pro - Modo
Post by SteedMaker »
I just purchased a CADMouse Pro and will be using it for the Foundry's Modo application. The default in Modo is for the middle mouse button to select through geometry. I have setup the middle button to orbit the geometry - that works. I then tried to set up the wheel button to act as the middle mouse to select through the geometry, but I don't see an option for setting that as a middle mouse button. I even tried using the middle mouse on the CADMouse as a middle mouse to click and drag across geometry to select through the geometry, but that didn't work either. Any suggestions?
Wheel Button.jpg (146.53 KiB) Viewed 2272 times
Middle Button.jpg (144.5 KiB) Viewed 2272 times
SteedMaker
Re: CADMouse Pro - Modo
I just figured out my problem - It wasn't obvious that Click Button - 3 is the middle mouse button.
