Fusion update breaks 'Lock to Sketch Plane' in SpaceMouse Settings (MacOS)
Also posted on Fusion 360 forum....I'm pretty certain I've narrowed this down to the 2.0.20256 update as it works flawlessly in 2.0.19994. Initially I thought it was related to the Sequoia update, however even when I did a clean install of Sonoma and Fusion, it still didn't work. The only way I was able to restore a version of Fusion *.19994 was from a Time Machine backup, which I now have 14 days before the update will be forced. Prior to getting to this point I had tried all of the various suggestions on this (and related) topics between the 3dConnexion and Fusion forms.
Re: Fusion update breaks 'Lock to Sketch Plane' in SpaceMouse Settings (MacOS)
Autodesk engineer verified that the camera view is causing this. Pasted from the forum.
I figured it out. Your camera is Perspective. Using perspective camera now defeats sketch lock. In the older builds it does not. I confirmed this by comparing old and latest builds with perspective camera Workaround: try the perspective with ortho faces camera to keep sketch lock functionality, while we work on the issue.
