Application Specific Settings
lvoorheis86
Post by lvoorheis86 »
With the latest 3dxWare software driver, how does one turn on or enable application specific radial menus and macros "FOR ALL" 3dconnection devices? I might have to resort to going back to a previous 3dxWare software version. This really hinders the usefulness of the devices. and has hindered my custom hotkey setups.
MikeTaku
Re: Application Specific Settings
Post by MikeTaku »
Hello, I hope you are doing well. If you are facing this issue you can fix this with 3Dconnexion menus and macros in 3dxWare, ensure your firmware and software are up-to-date, and reset your device settings if needed. Make sure you're setting up macros in the correct application profile, and test them carefully. Check for any conflicts with shortcuts in the software you're using and try running both 3dxWare and the application as Administrator. If problems persist then you need to visit 3Dconnexion’s support forums for more help.
skmiec
Post by skmiec »
Hi Ivoorheis86,
Thank you for your post.
The application specific feature is implemented only for Keyboard Pro. Can you explain in more detail your inconveniences?
