Fusion 360 does not orbit
Szabó Kristóf
Post by Szabó Kristóf »
I just bought a SpaceMouse Compact, and I would like to use with Fusion 360. I'm on MacOs 15.1 and 3DxMacCore version 1.3.6.516 (516) and 3DxWare version 10.8.6 (3819). In Fusion 360 I selected the latest option at SpaceMouse driver option.
The pan and the zoom work fine, but does not orbit. When I try to orbit the rotation center dot appears, but the object doesn't rotate (or any orbit move).
When I tried legacy option in Fusion 360 it worked, but I would like to use the latest driver because it has much more options.
Do you have any idea?
AmroSalih
Re: Fusion 360 does not orbit
Post by AmroSalih »
Click the Profile Name in the top right corner.
Select Preferences.
Click Restore defaults in the left bottom corner of the Preferences tab.
Restart Fusion.
Szabó Kristóf
Thank you Amro! As you suggested by email I uninstalled the driver and deleted the preferences files, and reinstalled the driver. It solved the problem.
exactlygrowl
Post by exactlygrowl »
Got it! I’ve followed these steps, but just to confirm, should I be restarting Fusion after each time I click "Restore defaults," or only after the final step? I just want to make sure I’m doing it correctly. Thanks!
AmroSalih
Post by AmroSalih »
