Spacemouse compact won't work with SolidWorks connected 2025
DesignUnit
Post by DesignUnit »
I have updated my solidworks connected to 2025 (3DEXPERIENCE R2025x HotFix 0.3) and since then my spacemouse doesn't work anymore.
It works with the trainer and in Cinema4D, but not with SolidWorks.
If i click the box "3dConnexion Add-in for SolidWorks" it shows a hook but doesn't change a thing when going back to my model - my spacemouse doesn't work.
When i go back to check again, the hooks are gone.
WIN 11 Pro
Version 23H2
64 bit
3DConnexion driver used: 3DxWare64_v10-9-1_b650
Is there something i can do to make it work again?
Geff
Re: Spacemouse compact won't work with SolidWorks connected 2025
Post by Geff »
I already opend a post about it: https://forum.3dconnexion.com/viewtopic.php?t=57090
It looks like that they're notrg else to do than wait for the next driver update. :cry:
DesignUnit
I saw that after posting my case.
Is there a timeline when the update will be ready?
Is there any specific bug you encountered in your workflow that you need an update to fix for your currently installed design software?
rosebl
Post by rosebl »
Geff wrote: Fri Nov 29, 2024 1:53 am Hello,
So when is the next update?
