infinite restart required loop 3dxware v10.9.1
jomazq
Post by jomazq »
I can't complete installation of 10.9.1.
after first attempt, I restarted my machine as prompted.
Since then I have been seeing a prompt of a system reboot being required, but the installation is not complete and 3dxware would not run.
subsequently, after trying multiple times I've rolled back to installing 10.8.9
unsuccessful installation log is below.
Not sure why I am experiencing an infinite loop at a restart being required, even though I've restarted many times.
restart required
restart required
restart required.png (21.34 KiB) Viewed 7427 times
[3338:FDE8][2024-12-06T11:33:41]i001: Burn v3.11.1.2318, Windows v10.0 (Build 19045: Service Pack 0), path: C:\Users\ladachi\AppData\Local\Temp\{99B3259E-56BA-4C1E-80E9-CCD54534C584}\.cr\install.exe
[3338:FDE8][2024-12-06T11:33:41]i000: Initializing string variable 'ProductPlatform' to value 'x64'
[3338:FDE8][2024-12-06T11:33:41]i000: Initializing string variable 'ProductBuildNum' to value '650'
[3338:FDE8][2024-12-06T11:33:41]i000: Initializing string variable 'ProductCommit' to value 'b9f3874e7bdf42fcab0745044e785b20360e5bab'
[3338:FDE8][2024-12-06T11:33:41]i000: Initializing string variable 'InstallFolder' to value '[ProgramFiles64Folder]3Dconnexion\3DxWare'
[3338:FDE8][2024-12-06T11:33:41]i000: Initializing string variable 'AutoCheckForUpdates' to value '1'
[3338:FDE8][2024-12-06T11:33:41]i000: Initializing string variable 'CleanSettings' to value '0'
[3338:FDE8][2024-12-06T11:33:41]i000: Initializing numeric variable 'DesktopIconExists' to value '0'
[3338:FDE8][2024-12-06T11:33:41]i000: Initializing string variable 'ShareAnalyticsData' to value '0'
[3338:FDE8][2024-12-06T11:33:41]i000: Initializing string variable 'LadpLangTransform' to value '1033.mst'
[3338:FDE8][2024-12-06T11:33:41]i009: Command Line: '-burn.clean.room=C:\Users\ladachi\AppData\Local\Temp\7zS8CB24164\install.exe -burn.filehandle.attached=856 -burn.filehandle.self=852'
[3338:FDE8][2024-12-06T11:33:41]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\ladachi\AppData\Local\Temp\7zS8CB24164\install.exe'
[3338:FDE8][2024-12-06T11:33:41]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\ladachi\AppData\Local\Temp\7zS8CB24164\'
[3338:FDE8][2024-12-06T11:33:41]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341.log'
[3338:FDE8][2024-12-06T11:33:41]i000: Setting string variable 'WixBundleManufacturer' to value '3Dconnexion'
[3338:FDE8][2024-12-06T11:33:41]i000: Loading managed bootstrapper application.
[3338:FDE8][2024-12-06T11:33:42]i000: Creating BA thread to run asynchronously.
[3338:0530][2024-12-06T11:33:42]i000: TDxBA: Running. Resume action: RebootPending
[3338:FDE8][2024-12-06T11:33:42]i100: Detect begin, 26 packages
[3338:FDE8][2024-12-06T11:33:42]i000: TDxBA: Detection begun. Bundle version: 10.9.1.650, Installed: False.
[3338:FDE8][2024-12-06T11:33:42]i000: Setting numeric variable 'AutoCheckForUpdatesKeyExists' to value 1
[3338:FDE8][2024-12-06T11:33:42]i000: Registry value not found. Key = 'SOFTWARE\3Dconnexion\3DxWare', Value = 'DesktopIcon'
[3338:FDE8][2024-12-06T11:33:42]i000: Setting numeric variable 'DesktopIconExists' to value 0
[3338:FDE8][2024-12-06T11:33:42]i052: Condition 'Not DesktopIconExists' evaluates to true.
[3338:FDE8][2024-12-06T11:33:42]i000: Setting numeric variable 'DesktopIconExists' to value 1
[3338:FDE8][2024-12-06T11:33:42]i000: Setting numeric variable 'InstallFolderExists' to value 1
[3338:FDE8][2024-12-06T11:33:42]i000: Registry key not found. Key = 'SOFTWARE\3Dconnexion\3DxAnalytics\Enabled'
[3338:FDE8][2024-12-06T11:33:42]i000: Setting numeric variable 'ShareAnalyticsDataExists' to value 0
[3338:FDE8][2024-12-06T11:33:42]i052: Condition 'InstallFolderExists' evaluates to true.
[3338:FDE8][2024-12-06T11:33:42]i000: Setting string variable 'InstallFolder' to value 'C:\Program Files\3Dconnexion\3DxWare\'
[3338:FDE8][2024-12-06T11:33:42]i052: Condition 'ShareAnalyticsDataExists' evaluates to false.
[3338:FDE8][2024-12-06T11:33:42]i000: Registry key not found. Key = 'SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{BAFCA6AC-8B37-405B-B57E-C1D45DE70ACC}'
[3338:FDE8][2024-12-06T11:33:42]i052: Condition 'AutoCheckForUpdatesKeyExists' evaluates to true.
[3338:FDE8][2024-12-06T11:33:42]i000: Setting string variable 'AutoCheckForUpdates' to value '1'
[3338:FDE8][2024-12-06T11:33:42]i000: Setting string variable 'NetFxRelease' to value '528372'
[3338:FDE8][2024-12-06T11:33:42]i102: Detected related bundle: {3e5e1864-229d-49bf-bda8-f689c6dbd80a}, type: Upgrade, scope: PerMachine, version: 10.8.3.3389, operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:42]i000: TDxBA: Detected related bundle {3e5e1864-229d-49bf-bda8-f689c6dbd80a}. Version: 10.8.3.3389. Type: Upgrade. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:42]i000: TDxBA: Upgrade detected. Old bundle version is 10.8.3.3389.
[3338:FDE8][2024-12-06T11:33:42]i052: Condition 'NetFxRelease >= 528040' evaluates to true.
[3338:FDE8][2024-12-06T11:33:42]i103: Detected related package: {5DB450DB-12DA-43B8-B530-645D4AEEE656}, scope: PerMachine, version: 10.8.3.3389, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxSoftware": "{5DB450DB-12DA-43B8-B530-645D4AEEE656}",  v. 10.8.3.3389. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {F456DC9E-0BCA-4C55-9FA9-012664421B24}, scope: PerMachine, version: 17.8.3.18895, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxWinCore": "{F456DC9E-0BCA-4C55-9FA9-012664421B24}",  v. 17.8.3.18895. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {61BEE16E-0556-4C29-9C14-DE02FE50B870}, scope: PerMachine, version: 1.1.0.44, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxViewer10": "{61BEE16E-0556-4C29-9C14-DE02FE50B870}",  v. 1.1.0.44. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {F4B62FE6-27F1-408B-A4E2-A3BE06DEA365}, scope: PerMachine, version: 1.4.1.18506, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxNLServer": "{F4B62FE6-27F1-408B-A4E2-A3BE06DEA365}",  v. 1.4.1.18506. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Do not pre-select _3DxAnalytics.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {EFC40EB4-F50B-4D1D-997A-79E90186B7D7}, scope: PerMachine, version: 2.9.5.18069, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxPhotoshop": "{EFC40EB4-F50B-4D1D-997A-79E90186B7D7}",  v. 2.9.5.18069. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {2CDAA352-3028-4DA7-833E-BA22DA8EB33F}, scope: PerMachine, version: 5.7.1.17918, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxAutoCAD": "{2CDAA352-3028-4DA7-833E-BA22DA8EB33F}",  v. 5.7.1.17918. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Selecting _3DxCinema4D since it was first included after current installation.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {EE2328AB-98AC-4B32-98D9-D8AD31E2A8C8}, scope: PerMachine, version: 3.4.21.18810, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxNX": "{EE2328AB-98AC-4B32-98D9-D8AD31E2A8C8}",  v. 3.4.21.18810. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {6B527314-CE72-4188-AD1D-331582F18188}, scope: PerMachine, version: 2.4.4.18413, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxProENGINEER": "{6B527314-CE72-4188-AD1D-331582F18188}",  v. 2.4.4.18413. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {DA49C5BC-375A-45EE-B96E-EB16BFBC32AB}, scope: PerMachine, version: 1.1.1.18704, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxMSOffice": "{DA49C5BC-375A-45EE-B96E-EB16BFBC32AB}",  v. 1.1.1.18704. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {3C9B782E-29B6-4084-AA6F-DF13A7A2F9C2}, scope: PerMachine, version: 2.4.0.18187, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxInventor": "{3C9B782E-29B6-4084-AA6F-DF13A7A2F9C2}",  v. 2.4.0.18187. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {FDAF3128-1900-4B53-85E5-9C8577A7EDA2}, scope: PerMachine, version: 5.2.0.17889, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxSketchUp": "{FDAF3128-1900-4B53-85E5-9C8577A7EDA2}",  v. 5.2.0.17889. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {CE3B5A0E-7E1F-40D7-A23C-1A6B49594811}, scope: PerMachine, version: 3.5.11.18523, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxSolidWorks": "{CE3B5A0E-7E1F-40D7-A23C-1A6B49594811}",  v. 3.5.11.18523. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {25D619FF-0DE9-421E-9741-018F59A5C262}, scope: PerMachine, version: 6.0.8.18367, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxMaya": "{25D619FF-0DE9-421E-9741-018F59A5C262}",  v. 6.0.8.18367. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Selecting _3DxNavisworks since it was first included after current installation.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {83ABBCBB-3E23-41B5-BBCC-3C84DA11A6D0}, scope: PerMachine, version: 7.0.8.18365, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxStudio": "{83ABBCBB-3E23-41B5-BBCC-3C84DA11A6D0}",  v. 7.0.8.18365. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Selecting _3DxUnity3D since it was first included after current installation.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {2DE77957-B486-41EF-80F6-0E32FF28AEA0}, scope: PerMachine, version: 1.1.1.49, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxUnreal": "{2DE77957-B486-41EF-80F6-0E32FF28AEA0}",  v. 1.1.1.49. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i103: Detected related package: {C2D9D6A1-F354-4CF0-A5E1-9F9EBB3E0D6D}, scope: PerMachine, version: 1.0.0.13, language: 0 operation: MajorUpgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Upgrade. Found related package to "_3DxRevit": "{C2D9D6A1-F354-4CF0-A5E1-9F9EBB3E0D6D}",  v. 1.0.0.13. Operation: MajorUpgrade.
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: NetFxWeb, state: Present, cached: None
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxSoftware, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxWinCore, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i104: Detected package: _3DxWinCore, feature: FeatureDfu, state: Absent
[3338:FDE8][2024-12-06T11:33:43]i104: Detected package: _3DxWinCore, feature: DefaultFeature, state: Absent
[3338:FDE8][2024-12-06T11:33:43]i104: Detected package: _3DxWinCore, feature: FeatureBrowsersDll, state: Absent
[3338:FDE8][2024-12-06T11:33:43]i104: Detected package: _3DxWinCore, feature: FeatureBrowsersDllDisjoint, state: Absent
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxViewer10, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: DemoPrograms, state: Present, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxTrainer, state: Present, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxNLServer, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxAnalytics, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxAdobe3D, state: Present, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxPhotoshop, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxAutoCAD, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxCinema4D, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxNX, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxProENGINEER, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxMSOffice, state: Absent, cached: None
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxInventor, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxSketchUp, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxSolidWorks, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxSolidEdge, state: Present, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxMaya, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxNavisworks, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxStudio, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxUnity3D, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxUnreal, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: _3DxRevit, state: Absent, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i101: Detected package: LADPInst, state: Present, cached: Complete
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Detection ended.
[3338:FDE8][2024-12-06T11:33:43]i000: Unsetting variable 'NoDesktopIcon'
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Set 'NoDesktopIcon' flag to value 'False'
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Command action: Install
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Detect state: Upgrade
[3338:FDE8][2024-12-06T11:33:43]i000: TDxBA: Planned action: Install
[3338:FDE8][2024-12-06T11:33:43]i199: Detect complete, result: 0x0
[3338:0530][2024-12-06T11:33:45]i000: TDxBA: HandleShareAnalyticsDataOption action begin.
[3338:0530][2024-12-06T11:33:45]i000: TDxBA: Modify or upgrade. Prompt user to select the "3Dconnexion Analytics" component.
[3338:0530][2024-12-06T11:33:46]i000: Setting string variable 'ShareAnalyticsData' to value '1'
[3338:0530][2024-12-06T11:33:46]i000: TDxBA: ShareAnalyticsData option set to "1".
[3338:0530][2024-12-06T11:33:46]i000: TDxBA: HandleShareAnalyticsDataOption action ended with value "True".
[3338:FDE8][2024-12-06T11:33:46]i200: Plan begin, 26 packages, action: Install
[3338:FDE8][2024-12-06T11:33:46]w321: Skipping dependency registration on package with no dependency providers: NetFxWeb
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxSoftware' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_000__3DxSoftware_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxSoftware' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_000__3DxSoftware.log'
[3338:FDE8][2024-12-06T11:33:46]i204: Plan 4 msi features for package: _3DxWinCore
[3338:FDE8][2024-12-06T11:33:46]i203: Planned feature: FeatureDfu, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[3338:FDE8][2024-12-06T11:33:46]i203: Planned feature: DefaultFeature, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[3338:FDE8][2024-12-06T11:33:46]i203: Planned feature: FeatureBrowsersDll, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[3338:FDE8][2024-12-06T11:33:46]i203: Planned feature: FeatureBrowsersDllDisjoint, state: Absent, default requested: Unknown, ba requested: Local, execute action: AddLocal, rollback action: Remove
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxWinCore' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_001__3DxWinCore_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxWinCore' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_001__3DxWinCore.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxViewer10' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_002__3DxViewer10_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxViewer10' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_002__3DxViewer10.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxNLServer' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_003__3DxNLServer_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxNLServer' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_003__3DxNLServer.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxAnalytics' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_004__3DxAnalytics_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxAnalytics' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_004__3DxAnalytics.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxPhotoshop' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_005__3DxPhotoshop_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxPhotoshop' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_005__3DxPhotoshop.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxAutoCAD' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_006__3DxAutoCAD_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxAutoCAD' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_006__3DxAutoCAD.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxCinema4D' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_007__3DxCinema4D_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxCinema4D' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_007__3DxCinema4D.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxNX' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_008__3DxNX_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxNX' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_008__3DxNX.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxProENGINEER' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_009__3DxProENGINEER_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxProENGINEER' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_009__3DxProENGINEER.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxMSOffice' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_010__3DxMSOffice_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxMSOffice' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_010__3DxMSOffice.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxInventor' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_011__3DxInventor_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxInventor' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_011__3DxInventor.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxSketchUp' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_012__3DxSketchUp_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxSketchUp' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_012__3DxSketchUp.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxSolidWorks' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_013__3DxSolidWorks_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxSolidWorks' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_013__3DxSolidWorks.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxMaya' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_014__3DxMaya_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxMaya' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_014__3DxMaya.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxNavisworks' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_015__3DxNavisworks_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxNavisworks' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_015__3DxNavisworks.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxStudio' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_016__3DxStudio_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxStudio' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_016__3DxStudio.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxUnity3D' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_017__3DxUnity3D_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxUnity3D' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_017__3DxUnity3D.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxUnreal' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_018__3DxUnreal_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxUnreal' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_018__3DxUnreal.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleRollbackLog__3DxRevit' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_019__3DxRevit_rollback.log'
[3338:FDE8][2024-12-06T11:33:46]i000: Setting string variable 'WixBundleLog__3DxRevit' to value 'C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_019__3DxRevit.log'
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: NetFxWeb, state: Present, default requested: Present, ba requested: None, execute: None, rollback: None, cache: No, uncache: No, dependency: None
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxSoftware, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxWinCore, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxViewer10, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: DemoPrograms, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxTrainer, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxNLServer, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxAnalytics, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxAdobe3D, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxPhotoshop, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxAutoCAD, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxCinema4D, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxNX, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxProENGINEER, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxMSOffice, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxInventor, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxSketchUp, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxSolidWorks, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxSolidEdge, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxMaya, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxNavisworks, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxStudio, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxUnity3D, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxUnreal, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: _3DxRevit, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i201: Planned package: LADPInst, state: Present, default requested: Present, ba requested: Present, execute: None, rollback: None, cache: No, uncache: No, dependency: Register
[3338:FDE8][2024-12-06T11:33:46]i207: Planned related bundle: {3e5e1864-229d-49bf-bda8-f689c6dbd80a}, type: Upgrade, default requested: Absent, ba requested: Absent, execute: Uninstall, rollback: Install, dependency: None
[3338:FDE8][2024-12-06T11:33:46]i299: Plan complete, result: 0x0
[3338:FDE8][2024-12-06T11:33:46]i300: Apply begin
[3338:FDE8][2024-12-06T11:33:46]i000: TDxBA: Terminating process "3DxService" (pid: 58712).
[3338:FDE8][2024-12-06T11:33:46]i000: TDxBA: Starting process C:\Program Files\3Dconnexion\3DxWare\3DxWinCore\3DxService.exe
[3338:FDE8][2024-12-06T11:33:46]i000: TDxBA: Starting process as current user.
[3338:FDE8][2024-12-06T11:33:46]i000: TDxBA: Waiting for helper process (pid: 12740) to close.
[3338:FDE8][2024-12-06T11:33:52]i000: TDxBA: Helper process (pid 12740) has closed.
[3338:FDE8][2024-12-06T11:33:52]i000: TDxBA: Waiting for process (pid: 58712) to close.
[3338:FDE8][2024-12-06T11:33:52]i000: TDxBA: Process (pid: 58712) has closed.
[3338:FDE8][2024-12-06T11:33:52]e000: TDxBA: Engine reported error code 350: No action was taken as a system reboot is required.
[3338:FDE8][2024-12-06T11:33:55]e000: TDxBA: Return Ok (1) to engine.
[3338:FDE8][2024-12-06T11:33:55]i399: Apply complete, result: 0x8007015e, restart: Required, ba requested restart:  No
[3338:0530][2024-12-06T11:33:58]i000: TDxBA: Quiting, exit code: 350 (350)
[3338:FDE8][2024-12-06T11:33:58]i500: Shutting down, exit code: 0x15e
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: AutoCheckForUpdates = 1
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: AutoCheckForUpdatesKeyExists = 1
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: CleanSettings = 0
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: DesktopIconExists = 1
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: InstallFolder = C:\Program Files\3Dconnexion\3DxWare\
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: InstallFolderExists = 1
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: LadpLangTransform = 1033.mst
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: NetFxRelease = 528372
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: ProductBuildNum = 650
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: ProductCommit = b9f3874e7bdf42fcab0745044e785b20360e5bab
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: ProductPlatform = x64
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: ShareAnalyticsData = 1
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: ShareAnalyticsDataExists = 0
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: VersionNT64 = 10.0.0.0
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleAction = 5
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleElevated = 0
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLastUsedSource = C:\Users\ladachi\AppData\Local\Temp\7zS831A9A0F\
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxAnalytics = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_004__3DxAnalytics.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxAutoCAD = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_006__3DxAutoCAD.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxCinema4D = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_007__3DxCinema4D.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxInventor = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_011__3DxInventor.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxMaya = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_014__3DxMaya.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxMSOffice = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_010__3DxMSOffice.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxNavisworks = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_015__3DxNavisworks.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxNLServer = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_003__3DxNLServer.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxNX = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_008__3DxNX.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxPhotoshop = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_005__3DxPhotoshop.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxProENGINEER = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_009__3DxProENGINEER.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxRevit = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_019__3DxRevit.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxSketchUp = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_012__3DxSketchUp.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxSoftware = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_000__3DxSoftware.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxSolidWorks = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_013__3DxSolidWorks.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxStudio = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_016__3DxStudio.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxUnity3D = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_017__3DxUnity3D.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxUnreal = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_018__3DxUnreal.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxViewer10 = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_002__3DxViewer10.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleLog__3DxWinCore = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_001__3DxWinCore.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleManufacturer = 3Dconnexion
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleName = 3Dconnexion 3DxWare 10
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleOriginalSource = C:\Users\ladachi\AppData\Local\Temp\7zS831A9A0F\install.exe
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleOriginalSourceFolder = C:\Users\ladachi\AppData\Local\Temp\7zS831A9A0F\
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleProviderKey = {bbfc67e7-4b76-49ab-9da4-db939da6c4af}
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxAnalytics = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_004__3DxAnalytics_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxAutoCAD = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_006__3DxAutoCAD_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxCinema4D = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_007__3DxCinema4D_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxInventor = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_011__3DxInventor_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxMaya = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_014__3DxMaya_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxMSOffice = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_010__3DxMSOffice_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxNavisworks = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_015__3DxNavisworks_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxNLServer = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_003__3DxNLServer_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxNX = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_008__3DxNX_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxPhotoshop = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_005__3DxPhotoshop_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxProENGINEER = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_009__3DxProENGINEER_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxRevit = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_019__3DxRevit_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxSketchUp = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_012__3DxSketchUp_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxSoftware = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_000__3DxSoftware_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxSolidWorks = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_013__3DxSolidWorks_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxStudio = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_016__3DxStudio_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxUnity3D = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_017__3DxUnity3D_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxUnreal = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_018__3DxUnreal_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxViewer10 = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_002__3DxViewer10_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleRollbackLog__3DxWinCore = C:\Users\ladachi\AppData\Local\Temp\3Dconnexion\Installation\3DxWare_20241206113341_001__3DxWinCore_rollback.log
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleSourceProcessFolder = C:\Users\ladachi\AppData\Local\Temp\7zS8CB24164\
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleSourceProcessPath = C:\Users\ladachi\AppData\Local\Temp\7zS8CB24164\install.exe
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleTag = 3DxWare_b650
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleUILevel = 4
[3338:FDE8][2024-12-06T11:33:58]i410: Variable: WixBundleVersion = 10.9.1.650
[3338:FDE8][2024-12-06T11:33:58]i007: Exit code: 0x15e, restarting: No
AmroSalih
Re: infinite restart required loop 3dxware v10.9.1
Post by AmroSalih »
