Fail to uninstall old driver.
David M. Hofer
Post by David M. Hofer »
Hello, I need to update to newer a driver to be able use 3D Space Mouse with Autodesk Fusion. Works just fine with Autodesk Inventor. Got the latest version driver downloaded tried to install it no go. Says I need to uninstall old first but that does not work either. This is a real pain for me since my 3D Space Mouse is down.
AmroSalih
Re: Fail to uninstall old driver.
Post by AmroSalih »
Which old version is it?
Either send me a PM with the log files or contact the technical support directly https://3dconnexion.com/support/
David M. Hofer wrote: Thu Feb 06, 2025 4:50 pm Hello, I need to update to newer a driver to be able use 3D Space Mouse with Autodesk Fusion. Works just fine with Autodesk Inventor. Got the latest version driver downloaded tried to install it no go. Says I need to uninstall old first but that does not work either. This is a real pain for me since my 3D Space Mouse is down.
Try to reinstall your currently installed 3DxWare version. Then uninstall it.
