Problems with 3DxSketchUp for Sketchup Pro 2020
Malafor
Post by Malafor »
I'm currently using a Spacemouse Pro with the latest drivers (v10-9-3_b671) and am having trouble getting it to work with Sketchup Pro 2020 (No intention to upgrade to newer versions as they require subscription).
The 3DxSketchUp that comes with the drivers is for 2021 and up only from what I can gather, is there any way I can get the older version of that extension somehow?
Or must I install a older set of drivers and if so which version?
Thank you for any help!
skmiec
Re: Problems with 3DxSketchUp for Sketchup Pro 2020
Post by skmiec »
Hi Malafor,
In order to use Sketchup Pro 2020 you will have to revert to driver version 10.8.21.
Malafor
Post by Malafor »
skmiec wrote: ↑Thu Feb 13, 2025 11:46 pm Hi Malafor,
Thank you, works now!
