Rotate spacemouse compact 90 degrees
Maddonk
Post by Maddonk »
Hi all,
I am very used to how I hold the Spacemouse and want to start using the buttons more in inventor. To do so, i want to rotate the Spacemouse by 90 degrees.
I would like to swap the X and Y axis. What would be the easiest way to achieve this?
I have found this old thread https://forum.3dconnexion.com/viewtopic.php?t=39904
Applying the same steps, with 'blender' changed to 'inventor', does not work.
Specifically, the changes applied in %appdata%\3dconnexion\3dxware\cfg do not hold. Upon the next startup, 'Inventor.xml' is reverted back to its original.
Does anyone know a quick solution?
Thanks!
skmiec
Re: Rotate spacemouse compact 90 degrees
Post by skmiec »
Hi Maddonk,
Please tell which version of the 3DxWare do you use?
I have checked and changes done in the Advanced settings are saved do you try to edit the settings in %appdata%\3dconnexion\3dxware\cfg base on those from Base.xml>
