I had a problem after installing the latest update (10.8.9) and got this:
"Failed to enable com.3dconnexion.driver : com.3dconnexion.driver:terminating_for_disable_but_still_running not in state to be enabled"
when trying to enable the Driver Extension (in Login Items & Extensions).
Based on that error message I tried quitting all 3Dconnexion apps listed in the Activity Monitor but that didn't help until I found com.3dconnexion.driver under 'Disk'. Quitting that let me enable the extension.
After restart, my SpaceMouse Wireless was not working in Plasticity (but did work in the trainer and Bambu Studio).
I reverted to 10.8.8 to get it working again.
Anyone else using Plasticity?
Latest not working in Plasticity
Re: Latest not working in Plasticity
Hi galexa
Thank you for your post.
For Plasticity versions 25.2.x you should keep using v. 10.8.8 (or older) of 3DxWare 10.
If you upgrade to Plasticity 25.3.x and newer plese start using v. 10.8.9 of 3DxWare.
