Flakey Behavior on Single Fusion 360 Project
pengel200
Post by pengel200 »
I have a single F360 project where the SpaceMouse Wireless is misbehaving. I'm not able to orbit around the z-axis. Also, if I use the navigation cube to set the view on a particular face (right, for example), and use the navigation cube rotate arrow to set the correct orientation (top-up, for example), as SOON as I TOUCH the SpaceMouse, the model jumps to a straigh-on view 90° clockwise. It's the same view it jumps to no matter what I set in the cube.
The scroll wheel on my mouse has no problem orbiting properly.
I can't replicate this in any other project. Also, I copied my component to a new project, and the same thing happens.
One other data point is that the basis of this model is an imported STEP file, in case that could be contributing.
Has anyone else had an issue like this? If so, did you find a fix?
