3dsMax 2026 + latest 3dx driver
IstanV
Post by IstanV »
Will it ever work with helper-objects? We reported this bug > 6 months ago! No solution yet ?!
AmroSalih
Re: 3dsMax 2026 + latest 3dx driver
Post by AmroSalih »
Support for 3ds Max version 2026 had been added and the latest 3DxWare driver versions contain a Plugin for your desired software.
The navigation of Helper Objects isn't enabled.
IstanV
Post by IstanV »
What does the statement "The navigation of Helper Objects isn't enabled" mean?
skmiec
Post by skmiec »
Hi IstanV
Currently I see that CoR is correctly working with helper objects using "Use selected item" option, moving them also works.
What different problems do you observe
IstanV
Post by IstanV »
I know - sometimes it seems to work.
But save/load/clone/scripting could stop it working.
The answer I reveived was, that CoR cannot work, since a helper does not hold geometrical information for calculating a volume.
The .max file, which I sent a while ago to the support, is still not working..
IstanV
Post by IstanV »
Can someone plz give me an anwer on this:
How can it be enabled?
IstanV
Post by IstanV »
There exists the report number TS-695 since March 2025 !!
Will this ever get fixed or will we get access to the plugin source code finally?
