Configuration question - Space mouse Enterprise
TORRES
Post by TORRES »
Hi everyone,
Is it possible to configure a key press (toggle on-off) for a key such as CTRL/ALT/etc, so i can select elements instead of having to press constantly the same key and selecting with the mouse?
Best Regards,
Sérgio Torres
AADA
Re: Configuration question - Space mouse Enterprise
Post by AADA »
Do you mean that you would like to toggle the CTRL or ALT key so that when it is enabled, it behaves as if it is being held down continuously, and when you press it again, it is released?
TORRES
Post by TORRES »
Yes, i would like to do that for a single key, or a combination of keys, is it possible?
There are Shift Lock and Ctrl Lock functions available.
These act like the Caps Lock key on the keyboard. Press once, Shift or Ctrl is pressed and remains. Press again, Shift or Ctrl is released.
More than likely, the Shift and Ctrl state will be released when the user switches focus to a new application.
There is no Alt Lock function. I don't recall why not.
