script question
[email protected]
script question
Post by [email protected] »
this script is working except I can't get the "Inventory" Button displayed in the LCD to fire off I and display the characters inventory. The code in question is bolded
<?xml version="1.0" encoding="utf-8" standalone="no"?>
<AppCfg xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" Default="false" CfgFormatVersion="1.3" ThisFileVersion="2.0">
<AppInfo>
<Signature>
<Name>re9</Name>
<ExecutableName>re9.exe</ExecutableName>
</Signature>
<Options />
</AppInfo>
<CfgProperties>
<ID>ID_re9</ID>
<Name>re9</Name>
<InheritsFromID>ID_Default_KMJ_Cfg</InheritsFromID>
</CfgProperties>
<ButtonActions>
<ButtonAction Type="Sequence">
<ID>ID_INVENTORY_FINAL</ID>
<Name>Inventory</Name>
<Sequence Pause="150">
<ActionID>KB_KeyDown</ActionID>
<KeyStroke>
<Key>0C</Key>
</KeyStroke>
<ActionID>KB_KeyUp</ActionID>
<KeyStroke>
<Key>0C</Key>
</KeyStroke>
</Sequence>
</ButtonAction>
</ButtonActions>
<!-- SPACE MOUSE ASSIGNMENTS -->
<Devices>
<Device>
<ID>ID_Standard_3D_Mouse</ID>
<AxisBank>
<Name>Default</Name>
<ID>Default</ID>
<!-- MOVEMENT STRAFE LEFT AND RIGHT -->
<Axis>
<!-- STRAFE LEFT -->
<Enabled>true</Enabled>
<Input>
<Min>-512</Min>
<Max>0</Max>
<Deadband>200</Deadband>
</Input>
<Output>
<RepeatStyle>PressAndHold</RepeatStyle>
<Reversed>false</Reversed>
<KeyStroke>
<!-- <Modifiers><Modifier>Control</Modifier></Modifiers> IF YOU NEED A CTRL KEY MODIFIER -->
<Key>04</Key> <!-- A KEY -->
</KeyStroke>
</Output>
</Axis>
<Axis>
<!-- STRAFE RIGHT -->
<Input>
<Min>0</Min>
<Max>511</Max>
</Input>
<Output>
<KeyStroke>
<Key>07</Key> <!-- D KEY -->
</KeyStroke>
</Output>
</Axis>
<!-- END OF SECTION -->
<!-- MOVEMENT FORWARD / BACKWARD -->
<Axis>
<!-- FORWARD -->
<Input>
<Min>-512</Min>
<Max>0</Max>
<Deadband>100</Deadband>
</Input>
<Output>
<KeyStroke>
<Key>1A</Key> <!-- W KEY -->
</KeyStroke>
</Output>
</Axis>
<Axis>
<!-- BACKWARDS -->
<Input>
<Min>0</Min>
<Max>511</Max>
</Input>
<Output>
<KeyStroke>
<Key>16</Key> <!-- S KEY -->
</KeyStroke>
</Output>
</Axis>
<!-- PUSH DOWN / PULL UP AXIS / COUCH / LOOK BEHIND YOU -->
<Axis>
<!-- PUSH DOWN MOUSE MOVEMENT -->
<Input>
<Min>0</Min>
<Max>511</Max>
<Deadband>225</Deadband>
</Input>
<Output>
<KeyStroke>
<Key>6</Key> <!-- C CROUCH -->
</KeyStroke>
</Output>
</Axis>
<Axis>
<!-- PULL UP MOUSE MOVEMENT -->
<Input>
<Min>-512</Min>
<Max>0</Max>
</Input>
<Output>
<KeyStroke>
<Key>1B</Key> <!-- SPACE BAR FLIPS YOU AROUND TO LOOK BEHIND YOU -->
</KeyStroke>
</Output>
</Axis>
<!-- TILT UP/TILT DOWN MOUSE MOVEMENT -->
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<ActionID>HIDMouse_Y</ActionID> <!-- MouseY -->
<Reversed>true</Reversed> <!-- SETS TO TRUE TO INVERT DIRECTION IF NECESSARY -->
</Output>
</Axis>
<!-- TWIST LEFT RIGHT USING MOUSE MOVEMENT -->
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<ActionID>HIDMouse_X</ActionID> <!-- MouseX -->
<Reversed>false</Reversed> <!-- SETS TO TRUE TO INVERT DIRECTION IF NECESSARY -->
</Output>
</Axis>
<!-- NOT ASSIGNED
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
<Reversed>false</Reversed> SETS TO TRUE TO INVERT DIRECTION IF NECESSARY
</Output>
</Axis> -->
</AxisBank>
</Device>
<!-- LCD BUTTON BANK ASSIGNMENTS -->
<Device>
<ID>ID_ProductID_C633</ID>
<ButtonBank Default="true">
<ID>Default</ID>
<Button>
<Input>
<ActionID>V3DK_1</ActionID>
</Input>
<Output>
<ActionID>ID_INVENTORY_FINAL</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>LongPressButton_1</ActionID>
</Input>
<Output>
<ActionID>Driver_Disabled</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_2</ActionID>
</Input>
<Output>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_3</ActionID>
</Input>
<Output>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_4</ActionID>
</Input>
<Output>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_5</ActionID>
</Input>
<Output>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_6</ActionID>
</Input>
<Output>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_7</ActionID>
</Input>
<Output>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_8</ActionID>
</Input>
<Output>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_9</ActionID>
</Input>
<Output>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_10</ActionID>
</Input>
<Output>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_11</ActionID>
</Input>
<Output>
</Output>
</Button>
<Button>
<Input>
<ActionID>V3DK_12</ActionID>
</Input>
<Output>
</Output>
</Button>
</ButtonBank>
</Device>
</Devices>
</AppCfg>
