Calendar notifications on my OLED display?
Aluvio
Post by Aluvio »
Hey guys
I’ve been trying to get my meeting reminders to show up directly on the SpaceMouse Enterprise screen so I don't have to keep switching windows while modeling. I installed a small utility to sync my Google calendars with the workstation's local feed but the LCD just stays blank or shows the old app icons. I thought the sync would be automatic once the bridge was active but nothing actually triggers on the device. My firmware is up to date and I've messed with the XML profiles without much luck. I'm definitely not a software dev so maybe I missed a simple setting in the driver. Has anyone managed to push external data like this to the hardware?
Aluvio
Re: Calendar notifications on my OLED display?
Post by Aluvio »
Small update after trying again.
Honestly I think I’m overforcing it a bit at this point. I rechecked everything: bridge, reboot, XML profiles… but the SpaceMouse is still stuck on the old icons. Nothing updates on the LCD side.
I also tried running a tool for sync Google calendars as a middle layer, thinking it could translate the events into something the local feed would actually pick up, but it didn’t change anything. The device just doesn’t react.
Feels more like a hardware limitation than a config issue now.
I’ll probably drop that approach and switch to something simpler like desktop overlays or system notifications, at least that actually works without hacking too much around.
It can't do that. Nice idea though.
