Radial Menu transparency bug in Inventor Sketch mode (SpaceMouse Enterprise)
cavemanmods
Post by cavemanmods »
Hello,I am facing a severe transparency issue with my Radial Menus, but only inside the Autodesk Inventor Sketch environment. In the 3D Part environment, the menus appear perfectly opaque.System Info:Device: SpaceMouse EnterpriseDriver: 3DxWare 10.8.x (latest)OS: Windows 11Monitor: Dual setup (Laptop + LG W2361V via HDMI)What I have already tried without success:Changed Inventor Theme (Light/Dark/High Contrast).Changed Inventor Hardware Settings (Performance/Quality/Compatibility).Manually added <RadialMenuOpacity>1.0</RadialMenuOpacity> to both Global.xml and Inventor.xml.Clean install of the 3Dconnexion drivers.The issue persists on both monitors. Attached are two photos showing the difference between 3D mode (Normal) and Sketch mode (Transparent).Is there a hidden setting or a registry fix to force 100% opacity in Sketch mode?
Στιγμιότυπο οθόνης 2026-05-09 010109.png (29.59 KiB) Viewed 1576 times
Στιγμιότυπο οθόνης 2026-05-09 001504.png (37.71 KiB) Viewed 1576 times
Στιγμιότυπο οθόνης 2026-05-09 001445.png (42.4 KiB) Viewed 1576 times
