Multiple Command Cycling on one function key
timwillhack
It would be great to build in a list of commands to cycle through for a function key. Say you want one key to cycle between three commands, rotate, move, scale. Each command would most likely have a different keyboard shortcut, but if you had a list of commands to cycle through, you could get to scale if you tap the button twice if the last time you tapped the button changed to rotate. This would make the 3d mice way more flexible. Anyway just an idea
Re: Multiple Command Cycling on one function key
You can implement your own button handling with 3DxWare 10. That sounds like a fine project.
