3Dxware driver install
I loaded the new driver for unix(solaris) as instructed but the driver will only work as root. When another user logs in the icon will not show. Am I missing something???
I assume the start of the driver comes from the /etc/inittab?
When a user logs in and the icon does not show up, please check in the process list whether the driver is running as root or as the logged in user. And let me know.
Could you please disable the entry from the inittab and launch the driver from the command line? Please add the option -debug and post the result/output here.
Yes, the start comes from inittab
Driver is running as root when user is logged in.
RESULTS...
3dxsrv.c,640: displayname = :0.0
3dxsrv.c :: startupCommandLine(), authGetUser(), user=root
UdDev: Opening Magellan device on serial port /dev/term/a
UdDev: Spaceball 5000 opened
UdDev: Opening SpaceBall 5000 RS232 device on serial port /dev/term/a
3dxsrv.c :: startupCommandLine(), XOpenDisplay called with display name=:0.0, display = 8ea10
3dxsrv.c :: startupCommandLine(), SUCCESS!
3DxWareUNIX = V1.2.0
Device = Spaceball 5000
Firmware = V8.20
Home directory: /
UiSb: Directory "/etc/3DxWare" opened for configs.
UiSb: Directory "//.3dxcfg" not found
UdDev: Unknown packet m0
UdTransXCM: unknown ClientMessage event
UdDev: Unknown packet pAA
UdDev: Unknown packet q00
UdDev: Unknown packet nM
UdDev: Unknown packet z
UdDev: Unknown packet c33
UdDev: Unknown packet b
RESULTS...
Firmware = V8.20
Home directory: /
Root is logged in. It does not run when a user is logged in. I do not get a startup completion when a user tries to run the driver.
3dxsrv.c,640: displayname = $DISPLAY set to :0
3dxsrv.c :: startupCommandLine(), authGetUser(), failed to get user
All the files and users are local to this SUN SOLARIS system... no nfs mounts.
From the instructions...
"Known issues:
- the driver has to run with root privileges."
So, how to make this happen?
"Known issues:
user not recognized
Hi aplachta,
I will send you a beta version of 3DxWareUnix. We did some modification concerning how to identify the logged in user.
Please let us know if this one works on your machine.
