missing transport DLL s80trans.dll
mccue
Post by mccue »
I've seen other similar posts from people who's buttons stopped working normally and who are getting missing DLL messages. In addition to this error message I also get one that says "The 3DxWare driver is already running." when I start Pro/Engineer. This one shows up 2 or more times during the Pro/E launch. I've enabled logging and posted below. Any help would be greatly apreciated, thanks!
8:33:16.369: 3DxWare driver startup: 1/28/2013 8:33:16
8:33:16.369: 3DxWare Driver Version 6.16.0 : July 3, 2012
8:33:16.370: -quiet -- disabled
8:33:16.370: -shutdown -- disabled
8:33:16.371: -protocol -- none given. All protocols enabled.
8:33:16.371: -com -- Disabled, using spcware.ini file settings.
8:33:16.371: -dev -- Disabled, using spcware.ini settings.
8:33:16.372: -eps disabled sending each event.
8:33:16.372: -log enabled
8:33:16.372: -logLevel ffffffff
8:33:16.373: -logFile C:\Users\Seth\AppData\Roaming\3Dconnexion\3DxWare\3DxWare.log
8:33:16.373: -searchWarnDlg enabled
8:33:16.374: -showGUI not enabled
8:33:16.374: -hideGUI not enabled
8:33:16.374: UdCtl: Attempting to find (ID=1033) 'English' locale in EN_US
8:33:16.375: UdCtl: Found resource DLL in C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\EN_US\3dxsrv.dll
8:33:16.417: UdCtl: initialization successful.
8:33:16.418: UdCtl: Attempting to open Any Device (-1) on USB.
8:33:16.419: UdCtl: Attempting to load device DLL: C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\UdDev\HIDDev.dll
8:33:16.473: UdDev: Attempting to open 3Dx-supported HID device on USB
8:33:16.513: UdDev: Beeping the device
8:33:16.513: UdDev: SpaceExplorer opened
8:33:16.514: UdCtl: Using device layer Any Supported 3Dconnexion USB Device supporting 0xffffffff
8:33:16.514: UdCtl: Device 0 (Any Device(-1) on USB) -- enabled.
8:33:16.515: Device Type: 4
Num Buttons: 15
Num DOF: 6
CanBeep: 1
Device Name: SpaceExplorer
Port Name: USB
Firmware: HID Firmware Version 4.14
Version 4.14
Orientation 0
8:33:16.520: UdCtl: Attempting to load UI DLL: C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\UdUi\udui.dll
8:33:16.535: UdUi: Launch3DxLCD
8:33:16.535: Launch3DxLCD: Invoking C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\3DxVirtualLCD.exe /pid=c627 /port="\\?\HID#VID_046D&PID_C627#9&14BE77D7&0&0000#{4D1E55B2-F16F-11CF-88CB-001111000030}" /action=hide
8:33:16.610: UdUi->InitDLL: UI DLL Initializing
8:33:16.742: UdUi->BuildAppNameLists: Unable to find valid ID section in file C:\Users\Seth\AppData\Roaming\3Dconnexion\3DxWare\profiles\user00.scg
8:33:16.742: UdUi->BuildAppNameLists: Unable to find valid ID section in file C:\Users\Seth\AppData\Roaming\3Dconnexion\3DxWare\profiles\user01.scg
8:33:16.789: UdUi->SetOrientation: About to create windows.
8:33:17.392: SetOrientation: B4 ResetAppNameBox call
8:33:17.393: 8:33:17.423: SetOrientation: After ResetAppNameBox call
8:33:18.243: UdUi->SetOrientation: Windows Created.
8:33:18.243: UdCtl: UI (3DxWare UI v3.0) initialized.
8:33:18.244: UdCtl: Attempting to load transport DLL C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\UdTrans\kbdtrans.dll.
8:33:18.249: kbdtrans: Keyboard transport layer initialization
8:33:18.249: kbdtrans: Function table load successful
8:33:18.254: kbdtrans: Unable to load SendKey.dll
8:33:18.254: UdCtl: Could not initialize transport layer kbdtrans.dll.
8:33:18.254: kbdtrans: 3DxWare Keyboard transport layer terminated
8:33:18.257: UdCtl: Attempting to load transport DLL C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\UdTrans\mwmtrans.dll.
8:33:18.262: mwmtranslog - Messages were registered
8:33:18.264: mwmtranslog - Opened hidden window
8:33:18.264: Mwmtrans: Username: Seth
8:33:18.265: mwmtrans: MagellanRPCServerInterface: endpoint is Magellan3DController
8:33:18.265: mwmtrans.dll:UdTransInit: NOT Terminal Services Environment
8:33:18.265: UdCtl: Transport DLL: mwmtrans.dll -- enabled
8:33:18.266: Name: Windows Messaging
8:33:18.266: Protocol ID: 10
8:33:18.266: Event Mask: 0x76
8:33:18.303: UdCtl: Attempting to load transport DLL C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\UdTrans\pxytrans.dll.
8:33:18.310: Loading Proxy DLLs
8:33:18.310: UdCtl: Transport DLL: pxytrans.dll -- enabled
8:33:18.311: Name: Proxy
8:33:18.311: Protocol ID: 5
8:33:18.311: Event Mask: 0x76
8:33:18.319: UdCtl: Attempting to load transport DLL C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare64\UdTrans\s80trans.dll.
8:33:20.278: UdCtl: Could not load transport DLL: s80trans.dll. Error=0x1e7
8:33:20.279: UdCtl: numWaitHdls: 1 numTransHdls: 0 numDevHdls: 1
8:33:20.288: UdCtl: udfenNT.dll loaded sucessfully
Re: missing transport DLL s80trans.dll
Hi mccue,
which version of ProE do you have?
ProE is launching the driver when you start ProE no matter if it is already running or not. As far as I know this command was deleted from ProE in the latest versions.
mccue
Post by mccue »
This is with WF4. It never used to be a problem, but I'm not sure what changed. Do you think that issue is related to the missing dll message?
Fred
Post by Fred »
The error "Could not load transport DLL s80trans.dll" occurs when there is either another program is using the file s80trans.dll or an anti-virus application is blocking it.
The 3Dconnexion software needs to be installed installed from a profile with full administrator privileges.If this is a network PC and you do not have full administrator rights, an IT tech would need to do the installation.
If you are installing the software from CD, you should instead download the current software from our web site at http://www.3dconnexion.com/support/downloads.php
Save the software to your PC then make sure you are logged in from an administrator profile.
To resolve the error " Could not load transport.." it is important to make sure all background applications are closed during the installation.One type of applications known to interfere in this way are programs to configure your standard mouse such as the MouseImp program. You need to turn the software off during the installation then you can turn it back on after the 3Dconnexion device is installed.
This type of background program can be turned off either from its SystemTray icon or using msconfig to temporarily prevent it from starting. If you are not sure which of the background applications may be causing the problem Microsoft has 'clean startup' steps here : http://support.microsoft.com/kb/331796
The other type of application that causes this type of .dll error is anti-virus/spyware applications. If this is a personal PC it is best to disconnect from the internet then turn all of the security software to complete the installation.
Hi mccue,
we released a new version of 3DxSoftware yesterday. That should fix the DLL errors coming up. Please give it a try and let us know.
defreestijl
Post by defreestijl »
UtaSH wrote:Hi mccue,
HI, I had the same problem in the Win 8, then I download the latest drivers and installed it, but is still didn't work,
then I removed the old software from control panel and reinstalled again,
now it works just fine.
