Problem: 3DConnexion doesn't work
imnumberone
Post by imnumberone »
I tried to open 3DxTest demo solution inside 3DConnexion SDK by Visual Studio 2008 and everything work fine (3D Mouse works)
Because i need to implement these code to my own project. So i create a new project Win32 windows application (empty project and then try not empty project).
With empty project: I create MyMouse.c and copy all code from 3DxTest32.h and 3DxTest32.c to it. Then compile is OK, but when i run the text didn't change.
With none empty project: same thing happens, compile is OK, but 3D Mouse didn't work.
I try to change resource file, and config file as the demo solution, but nothing change.
So, can anybody tell me why compile is OK, but it doesn't work?
Re: Problem: 3DConnexion doesn't work
You may need to create a profile for your new application. What profile does the 3Dx systray icon say the driver is using when your application is in focus?
imnumberone
I create new profile name mymouse as your instruction and it still doesn't work. I think the different is res/app.rc2 file, don't i?
imnumberone
VS_VERSION_INFO VERSIONINFO
 FILEVERSION IDR_3DXTEST_FILEVERSION_NUM
 PRODUCTVERSION IDR_3DXWINCORE_PRODUCTVERSION_NUM
 FILEFLAGSMASK 0x17L
#ifdef _DEBUG
 FILEFLAGS 0x1L
#else
 FILEFLAGS 0x0L
#endif
 FILEOS 0x4L
 FILETYPE 0x1L
 FILESUBTYPE 0x0L
BEGIN
    BLOCK "StringFileInfo"
    BEGIN
        BLOCK "040904b0"
        BEGIN
            VALUE "FileDescription", "3DxTest Application"
            VALUE "FileVersion", IDR_3DXTEST_FILEVERSION_STR
            VALUE "InternalName", "3DxTest"
            VALUE "LegalCopyright", IDR_LEGALCOPYRIGHT_ENUS
            VALUE "OriginalFilename", "3DxTest.exe"
            VALUE "ProductName", " 3DxTest Application"
            VALUE "ProductVersion", IDR_3DXWINCORE_PRODUCTVERSION_STR
        END
    END
    BLOCK "VarFileInfo"
    BEGIN
        VALUE "Translation", 0x409, 1200
    END
END
imnumberone
Here is my sample code, can you show me what is the problem? Because compile and run are OK, but i can not get 3DMouse handle.
#include <windows.h>
#include <stdio.h>
#include "spwmacro.h"  /* Common macros used by SpaceWare functions. */
#include "si.h"        /* Required for any SpaceWare support within an app.*/
#include "siapp.h"     /* Required for siapp.lib symbols */
SiOpenData oData;      /* Platform-specific device data */
SiGetEventData eData;  /* Platform-specific event data */
SiHdl hdl;             /* 3DxWare device handle */
SiSpwEvent siEvent;    /* 3DxWare data event */
LRESULT CALLBACK WndProc (HWND, UINT, WPARAM, LPARAM) ;
int WINAPI WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
	PSTR szCmdLine, int iCmdShow)
	static TCHAR szAppName[] = TEXT ("HelloWin") ;
	HWND         hwnd ;
	MSG          msg ;
	WNDCLASS     wndclass ;
	wndclass.style         = CS_HREDRAW | CS_VREDRAW ;
	wndclass.lpfnWndProc   = WndProc ;
	wndclass.cbClsExtra    = 8 ;
	wndclass.cbWndExtra    = 0 ;
	wndclass.hInstance     = hInstance ;
	wndclass.hIcon         = LoadIcon (NULL, IDI_APPLICATION) ;
	wndclass.hCursor       = LoadCursor (NULL, IDC_ARROW) ;
	wndclass.hbrBackground = (HBRUSH) GetStockObject (WHITE_BRUSH) ;
	wndclass.lpszMenuName  = NULL ;
	wndclass.lpszClassName = szAppName ;
	if (!RegisterClass (&wndclass))
		MessageBox (NULL, TEXT ("This program requires Windows NT!"),
			szAppName, MB_ICONERROR) ;
		return 0 ;
	hwnd = CreateWindow (szAppName,                  // window class name
		TEXT ("HelloWin"),		// window caption
		WS_OVERLAPPEDWINDOW,        // window style
		100,              // initial x position
		100,              // initial y position
		230,              // initial x size
		280,              // initial y size
		NULL,                       // parent window handle
		NULL,                       // window menu handle
		hInstance,                  // program instance handle
		NULL) ;                     // creation parameters
	ShowWindow (hwnd, iCmdShow) ;
	UpdateWindow (hwnd) ;
	SiOpenWinInit (&oData, hwnd);
	if ( (hdl = SiOpen ("HelloWin", SI_ANY_DEVICE, SI_NO_MASK,
		SI_EVENT, &oData)) == SI_NO_HANDLE);
		/* Get and display initialization error */
		MessageBox (NULL, TEXT ("Could not open a 3DxWare device"),
	while (GetMessage (&msg, NULL, 0, 0))
		SiGetEventWinInit (&eData, msg.message, msg.wParam,
			msg.lParam);
		if (SiGetEvent (hdl, 0, &eData, &siEvent) == SI_IS_EVENT)
			switch (siEvent.type)
			case SI_MOTION_EVENT:
				break;
			case SI_ZERO_EVENT:
				break;
			case SI_BUTTON_EVENT:
				break;
			default:
				break;
			} /* end switch on 3DxWare event type*/
		} /* end if the event was a 3DxWare event */
		else
			TranslateMessage (&msg);
			DispatchMessage (&msg);
	* Close connection to the 3DxWare driver.
	SiClose (hdl);
	SiTerminate ();
	return msg.wParam ;
LRESULT CALLBACK WndProc (HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam)
	HDC         hdc ;
	PAINTSTRUCT ps ;
	switch (message)
	case WM_CREATE:
		return 0 ;
	case WM_PAINT:
		hdc = BeginPaint (hwnd, &ps) ;
		EndPaint (hwnd, &ps) ;
		printf("Paint");
		return 0 ;
	case WM_DESTROY:
		PostQuitMessage (0) ;
		return 0 ;
	return DefWindowProc (hwnd, message, wParam, lParam) ;
imnumberone
Oh gosh, the stupid error i have met. Can you distinguish 2 blocks of code below?
This code is work
SiOpenWinInit (&oData, hWnd);
 if ( (hdl = SiOpen ("app name", SI_ANY_DEVICE, SI_NO_MASK,
    MessageBox (hWnd, "Could not open a 3DxWare device", NULL,
                MB_ICONSTOP | MB_OK);
This code is not
Because i copy it from document SDK, some fonts not work, i need to type on my own and then it works :D
You have a suspicious semi-colon at the end of an if() statement.
There are no differences between the code snippets.
Did I win? Where's my prize?
