SpaceNavigator seems dead!?
zaagaard
Post by zaagaard »
Hi there
When i started up my computer today my spacenavigator didn't start!? Then i tried clicking "start driver" and nothing happened. Then i uninstalled the driver and downloaded a new, installed it and it still doesn't work.
My computer does not registrete when i remove the spacenavigator and plug it back in!?
I can't get it to work!
Can anyone help?
/Allan
takedownca
Post by takedownca »
This shouldn't be necessary, but try plugging it into a different usb port.
Fred
Post by Fred »
takedownca
Make sure you have the Navigator plugged into the usb port on the pc and not through any type of hub or docking station.
What OS are you using?
Vista has security features which can block ports etc.
Check your usb devices in the hardware configuration make sure they are up dated and enabled.
If you still have problems
Give us a call.
Here is the link.
http://www.3dconnexion.com/support/4d.php
Fred
Rob_N
Post by Rob_N »
mine did that the other day, I held down both buttons while plugging it in, and then windows "found" it again.
I still need to call tech support on it, but its working now.
I have the PE edition, do I even get Phone support with it? I thought it was web only
agoenczi
User
User
SpaceNavigator Personal Edition (PE)
Post by agoenczi »
Hi Rob_N
For a SpaceNavigator PE you will get only web support. That's why the price is lower.
If you would like to get phone support too you can upgrade any time to a Standard Edition. This upgrade will allow you to get full support: phone, e-mail, web form, fax. It's up to you...
agoenczi
aiverson
Post by aiverson »
has anyone figured this out , I have the same problem and the "press and hold the two buttons down while you plug it in trick" does work but, I should have to do that. OS is xp home ed sp2. It worked when I first installed it, I then rebooted and I can't get the driver to start or the navigator to light up unless I do the two button trick. please help
Tony
Hi aiverson,
What you reported is consistent with a hardware problem. Please contact the 3Dconnexion Customer Service to check if it necessary to replace your 3D mouse. Contact details are available here.
Also note that all customers -- irrespective of device editions -- are entitled to phone and E-mail support for hardware problems. 3Dconnexion will replace or repair any malfunctioning hardware if it is under warranty.
