3DXSRV.EXE using an entire core
joq
Post by joq »
Running a Core 2 Duo, Win 7 64 SP1, Autodesk Inventor 2014 Pro.
Every 10 - 15 minutes I get a severe lag from everything I try to do. Inventor commands grind to a halt, background apps (Pandora for example) start skipping. Go to task manager and see nothing. Nothing, except when I start moving the 3D Navigator. During this prolonged lag spike, 3dxsrv.exe consumes 50% of CPU resources (an entire core), but only when I try to use it. Then after a couple of minutes the lag inexplicably goes away and the exe is back to normal usage. I've had this problem for quite a while and through driver upgrades of the Navigator.
3DConnection SpaceNavigator
Software Release: 3.17.6
Driver Version 6.17.6
Firmware Version 3.18
joq
Re: 3DXSRV.EXE using an entire core
Post by joq »
Still having the same issues.
Hello joq,
which antivirus software do you have installed? Do you see an improvement of the situation if you create an exception for the driver in your antivirus software?
