I recently purchased a SpaceMouse Pro (which I'll never be able to live without), installed it with no problems, fired up Maya and was in modeling heaven. However, when starting Maya, roughly 85% of the time my system hangs, but is not locked up. I'm running OSX 10.9 with Maya 2014 SP3. After letting the machine sit for anywhere from 5-10 minutes, the system resumes normal operation with a dialog asking me if I want to allow Maya to accept incoming connections (which didn't happen prior to installing the Spacemouse). I've set the firewall in OSX to allow Maya all connections and can't seem to find any settings that could be used as a workaround... Does anyone have a thought on how I can get Maya to stop hanging during startup?
Thanks!
Maya 2014 Hangs When Starting
Re: Maya 2014 Hangs When Starting
Hello ESquared,
can you see which process makes the machine hang?
