Copy Settings?
tongy66086
Copy Settings?
Post by tongy66086 »
Is there a way to copy my settings from a computer I had to a computer that IT says I need?
I use Inventor 2014 and a space pilot pro.
I installed the space pilot pro on my new computer, and none of my buttons are working.
Is there a way to copy my settings from my old computer and install on my new?
What do I need to do to get my space pilot to work with Inventor?
Any help will be greatly appreciated.
Space Pilot Pro
Lenovo T520
Windows 7 SP1
Inventor 2013
Fred
Re: Copy Settings?
Post by Fred »
The 3Dconnexion button mappings are saved as .scg files. These are text format files where device settings and button mappings for most applications are stored. A few applications also store button mapping information in the registry.
Configurations for your 3Dconnexion device are located in these two places. Location 1 is the filesystem location for the various operating systems and Location 2 is the Windows registry location.
1.WinXp
C: --> Documents and Settings --> [Username] --> Application Data --> 3Dconnexion --> 3DxWare --> profiles
Vista :
C: --> Users --> [Username] --> AppData --> 3Dconnexion --> 3DxWare --> profiles
Windows 7 :
C: --> Users --> [Username] --> AppData -->Roaming---> 3Dconnexion --> 3DxWare --> profiles
2: HKEY_CURRENT_USER --> Software --> 3Dconnexion --> ...
To transfer the configurations to another PC.
1: Copy .scg files to:
WinXP
Vista
Windows 7
2: Export the registry key from the old profile and import it into new one.
As always, remember to backup your registry before making any changes. You can make backup copies of the .scg files or use them to transfer settings to a new PC, however,they will only be of use to transfer to a new PC using the same operating system as your old system. Transferring configuration files from XP to Windows 7 does not work correctly due to the differences in security between the 2 operating systems.
To find out which .scg file your application is using, hover over the 3Dx SystemTray icon with your standard mouse while the application has the device focus. The profile name is listed along with the .scg filename in parenthesis - i.e GoogleEarth - uname(user05.scg)
tongy66086
Re: Copy Settings?
Thank you very much for your help.
All seems to be working correctly now.
Space Pilot Pro
Lenovo T520
Windows 7 SP1
Inventor 2013
