Good day ! I used SpaceMouse Pro with NX 8.5 and now I am migrating to NX 9.0. But I have some problem with dll files. I copy 3DxNX.dll, 3DxNX.men, 3DxNX.tbr, 3DxNXPopup.men to C:\Program Files\Siemens\NX 9\UGALLIANCE\vendor\startup and also add UGII_3DCONNEXION_LIBRARY=${UGII_BASE_DIR}\UGALLIANCE\vendor\startup\3dxnx.dll in ugii_env.dat (System value was already renamed). When I run NX 9 it has an error ugraf.exe "The proccedure entry point UF_SF_locate_material could not be located in the dynamic link lybrary libufun.dll".
Who knows the cause of this error?
SpaceMouse Pro and Siemens NX 9
Re: SpaceMouse Pro and Siemens NX 9
Hello N1ghtman,
which driver version do you have installed? I recommend to do a clean uninstall and re-install as described here.
Hi UtaSH! Thanks for help. I installed the latest version of the driver and now it's working! But now it doesn't work with Siemens NX 8.5 )))
Hi N1ghtman,
it doesn't work at all? Or can you navigate with the 3D mouse, but you do not have the button mapping available? Or do you now get the error that you previously had with NX 9??
Please see this information what to do if you have more that one NX installation on your machine.
