Hi
after update icon of Zoom Iso ist inverted
i work on gibbscam
http://zapodaj.net/e4cac287a3995.jpg.html
how can i inverted it?
thanks !
Problem after Update Wizard
Re: Problem after Update Wizard
Hi arashi -
There are two different zoom directions available - you can use 3Dconnexion Properties to change to the opposite zoom direction.
With your application [GibbsCam] active, open the 3Dconnexion Properties window. You can open 3Dconnexion Properties from 3DMouse Home - Properties, from the 3Dconnexion icon in the System Tray or from the 3Dconnexion folder on the Start menu.
The location in 3Dconnexion Properties to change zoom direction depends on the driver you are using.
In the 3DxSoftware driver [ Space Navigator, Space Pilot, Space Pilot PRO, Space Explorer, Space Mouse pro] the zoom direction is on the Device Configuration tab.
In the 3DxWare driver [Space Mouse Wireless] the zoom direction setting is under
'Advanced'.
Barbara
'Advanced'.
Barbara
