I´ve just instaled the new drivers for 3dsMax 9 x64 v. 4.4.3 and a couple of errors appears.
The first one:
DLL <C:\Program Files\Autodesk\3ds Max 9\stdplugs\3dxstd.dlu> failed to initialize.
Error code 14001 - it was impossible to start the application because your configuration is incorrect. Reinstalling the application you can solve the problem.
Please, in Max9 I can´t use my new SpacePilot, what can I do?
Thanks in advance
(excuse my bad english)
3ds Max 9 x64 drivers doesn´t work
Re: 3ds Max 9 x64 drivers doesn´t work
The 3Dconnexion devices depend on 3Dconnexion plug-in for 3DsMax for navigation inside the application. If your SpacePilot is working outside of 3DsMax , either the plug-in for 3DsMax is not installed or it does not have the proper permissions.
In the event that your version of 3DsMax was installed as administrator, you would need to add "Run as Administrator" permission to the 3Dx driver 3dxsrv.exe.
The default location of 3dxsrv.exe is C:-->Program Files-->3Dconnexion-->3Dconnexion 3DxSoftware-->3DxWare64--> 3dxsrv.exe
With 3DsMax closed, stop the driver, add the permission then re-start the driver. [Start, All Programs, 3Dconnexion, Driver, Start Driver| Stop Driver]
Right-click 3dxsrv.exe - Select Properties , then Compatibility and check only 'Run as administrator'.
The Modify /Repair function should add the 3DsMax plug-in as long as 3DsMax is closed during the process and you have the current driver installed. With the plug-in installed there is a 3DMouse news windows that opens initially when you open 3Dsmax. You should see the 3DsMax Pop-Up Menu when you press the Menu button on the SpaceMousePRO and SpacePilotPRO, the Panel button on the SpaceExplorer or the left SpaceNavigator button.
Hi miranda99,
is your installation of 3dsMax a 64bit or a 32bit version?
Check if the properties of the file 3dxstd.dlu in these two locations are the same (size, date):
- C:\Program Files\3ds Max 9\stdplugs
C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxStudio64\x64\3ds Max 9
