SpacePilot Pro going crazy
IndigoMertel
Post by IndigoMertel »
My SpacePilot Pro is going crazy. It looks as the software controlling the device enters into a loop. The LCD screen start cycling through several commands and applications are launched in sequence. I had to unplug the USB plug because I was not able to use the computer because of all the applications starting in sequence. The applications were still launched even after I unplugged the device and I had to stop the driver. I use Windows 7 64-bit and 3DxSoftware64SPP_v3-17-8_r1730. The device is approximately 3-4 years old.
Is there anything I can do to resolve this problem?
Re: SpacePilot Pro going crazy
Hello IndigoMertel,
it might be a hardware problem. Please try the following:
  • unplug the device
  • stop the driver
  • plug the device in and see if you get any erratic events
Next step:
  • start the driver, but do not touch the device
  • see if you get any erratic events
Let me know your findings.
Which application do you use with the 3D mouse?
IndigoMertel
Hi UtaSH, thank you for your reply.
Your suggestion seemed to have fixed the problem. I have also tried to press every single button to see if the problem occurred again but it seems to be ok now. Thanks a lot!
I use the device with Blender.
IndigoMertel
I spoke too early. After about 1/2 hour the device started displaying the same problem. I wasn't even using it, the event sequence started while I was using another computer.
Any idea?
If the erroneous movement happens regularly your 3D mouse might be faulty.
I recommend to contact our Technical Support. They can assist and check if the device is still under warranty. They will as well assist you in getting a replacement if the warranty is still valid.
IndigoMertel
Thank you, UtaSH. I will contact support.
