Internal Error 2753. tdxinput.dll
Hello I have Windows 8.1 (x64), SpaceNavigator and stood driver version 3.17.8 (x64) - all worked fine. 2 weeks ago went to the site and saw the new version 10.0.22 (x64). First remove the old drivers and installing the 10.0.22 at the beginning of write error «Internal Error 2753 . tdxinput.dll», click «OK», immediately another window appears with the inscription «3Dxconnexion 3DxWare (x64) installation failed. Error. 1603 . " If you continue, you and all other additions are the same line, if interrupted , then writes back «Internal Error 2753 . tdxinput.dll». I have deleted these drivers completely from the registry and put the old one, in which there are the same mistakes. Checked that I have the right to write to the registry. Run from the local hard disk. What else?
Re: Internal Error 2753. tdxinput.dll
Hello misha,
if you haven't yet tried please install the previously installed version of the driver and then do an uninstall again.
If this doesn't help try to remove any rest from the installation with this tool from Microsoft.
Let me know if you can fix the issue. Thanks.
Older versions are not installed , still the same error «Internal Error 2753 . tdxinput.dll ». "Microsoft Fix it" says " No errors were detected ." Again, completely delete all of the registry with the rights and "System" and "Administrator" , rebooted , install or 3.17.8 (x64) or 10.0.22 , still the same error «Internal Error 2753 . tdxinput.dll »! If you unzip the installer and install everything separately , for example « 3DxSolidWorks64.msi », then install all the add-ons writes :« Error 1714 ..... "although everything connected with 3Dconnexion, 3DxWare, 3DxSolidWorks, 3DxSolidEdge , 3DxSketchUp, 3DxAdobe3D ....... completely deleted from the registry . What else can I do without reinstalling Windows?
Please create log files with this instruction. If you have the log files zip them into one file and send it to me. I will PM you an email address.
Hello UtaSH.
That this team 3DxSoftware64_v3-17-8_r1730.exe / c: "3DxSoftware64 / a / z '/ logpath = c: \ temp'", tried to establish. All the same samoe. Logi attached.
- Attachments
- LOG.zip
- (201.28 KiB) Downloaded 1256 times
I'll look into the logs and will come back to you.
