Rhino Keyboard Buttons Changed in 10.1.0
chemosavi
Post by chemosavi »
I just updated to Version 10.1.0 and on Rhino I can no longer switch say the esc button to the shift button. I have to assign a macro to do this but the macro works completely different than a regular key.
To further explain, when trying to select multiple objects a person would hold the shift key down while doing so.
Trying to use a macro instead executes the shift function as a press and release situation and will not let you select other objects.
In other programs like 3ds max or chrome this is not the case. You can easily switch the alt key to the ctrl key no problem under keyboard functions/assignments.
In the previous releases this was not the case.
Please instruct to accomplish this or change it back to what worked.
20 core Xeon Workstation @3.1gz
3 Titan x's
Space Mouse Pro
Re: Rhino Keyboard Buttons Changed in 10.1.0
chemosavi
Post by chemosavi »
Thanks very much!
3 Titan x's
Space Mouse Pro
